Very weird
Overkill-X
A friend of mine has been overclocking his cpu.
But im having problems to believe this
Look here
Thats with the standard intel hsf , a superflower 300 watt psu and 4 casefans. (he left his window open for this pic lol)
And my 2.8c does 3.64 ghz at 35 degrees idle and 45 degrees on load with a goddamn SP-94 with enermax 92 mm fan on it.
So err is his temp probe busted or something?
Look here
He has a 17C mobo temp?
Unless he has a window open or something to cool below a normal a room temp, there is no way he can have a legit 17C temp without watercooling or some other after-market cooling measure
He has the window of his room open yes but 3750 mhz at 19 degrees on a stock intel cooler??
Heh..unless the air coming is bitter, bitter, cold, he's BSing you
