Very weird problem
Bleed
this is really weird. i have a certain folder in my storage drive that if i open it, it just closes itself. anybody know whats causing this? i had the same problem long time ago, i deleted the folder cause i found no solution for it :(.
Try to access the folder in the command prompt. :) Or, try moving the folder around, or archiving it. Umm, not too much info to work on though. I don't know about anyone else, but I like to have a little info on the system.
As a side note, is the folder in an area that wouldn't normally allow access? Like hidden folders and the like? Windows like to hide and restrict access to shit, and if the options are still on, it won't let you do much to it. I doubt that's the case though, if you can delete it.
Maybe a little more info will shed some light on the problem? :)
nothings really important inside the folder. just my anime episodes. might have been something to do with a certain codec that i downloaded yesterday. i just did a system restore, and everything is back to normal.
Hey, glad to hear you fixed it. :) Hopefully, the problem wont' reproduce itself. heh. System rollback can be awesome sometimes.
