Vertical Banding
Azphira
Any Idea what causes these lines on certain colors with the P95F+? This is the third replacement. The first one had the lines worse and color discoloration on the left side. The second monitor had frequent pin holes on the phosphor coating , severe geometry distortion and the lines to a less degree, this third monitor is best with the lines the faintest. It seems the lines are a design characteristic of this model number, they are a lot less noticeable than the horizontal stabilization wires, and the color clarity makes me tolerate the vertical glitch.
There is nothing to interfere with the monitor near it, everything has been tried short of opening the monitor and making adjustments.
This picture is from the second replacement. The lines are in the center closer to the task bar.
Monitor Lines
