Velociraptor 300GB
vjcsmoke
Just got me a brand new one for $150 shipped. :)
When SSDs go down in price, I'll get one for my C drive.
But the Velocirpator is gonna be my gaming drive! :D
SSD for ALL. Outa space? BUY MORE N RAID 'EM.
Only static storage deserves a mechanical disk IMO.
I got it from ebay. It's brand new btw.
Anyways the drive arrived today, and it's 2.5 inch form factor!
It was so small and light, I was afraid that the box was empty!
What do I do? Should I sell off the drive or buy a hd bay adapter so it can plug into a 3.5 drive slot?
Cos there's no where to put it right now, unless I want to make it the world's fastest PS3 sata hard drive!
And that would be pretty ridiculous cos I got my PS3 for like $300 and this drive was $150.
that 3.5 drive adapter you talked about is a giant heatsink. it keeps the drive cool. if you remove it, and try to place the drive into a ps3, the drive will have no way to cool itself properly. It wont fit in a PS3 btw, i think it's too long.
edit: i'd only use 5400RPM HDDs for the PS3. you dont really see faster load times with faster drives, on the ps3 anyway. plus they are cheaper and run cooler
it would overheat and break...
No it won't. WD sells it without the heatsinks on it's own. The drive produces less heat than a regular 3.5" drive as well. The heatsink was originally included so that the drive could be mounted in a 3.5" bay without buying any adapters. As for the PS3, it won't fit due to thickness, not length.
it seems like many other people are saying the velociraptor is fine w/o the heatsink, so i guess i was wrong on that. weird.
What is the thickness of a PS3 hard drive? I thought all 2.5" hard drives had the same size/thickness?
Nope, there are ones that are made for laptops and then there are ones that are made for enterprise use - different sizes.
Wow Shady, that looks great. Unfortunately all of my 5.25 inch bays are full. And I already ordered the Icybox 2.5 to 3.5 bay converter. Thanks for the suggestion though. If I ever decide to pull out an optical drive to free up a 5.25 inch bay, I'll keep that item in mind.
Actually that fits in a 3.5inch bay. There is another that fits in 5.25 inch bay and supports up to three 2.5inch SSDs/HDDs.
