Vegas Style BSOD
LOL, nice. I would say they are using Vista but in the second pic, that obviously isnt the new interface.
What amazes me is how low of a resolution that enormous screen uses. It looks to be something like 320x240...
If they used a high resolution panel, it would be a waste of money. People are far away reading the signs. Visual acuity doesn't much matter when you get to a certain distance, but the font needs to be large in order to read it.
i work in a convention center that has a 90' x 9' video wall. (32,000x768 if I recall correctly, over 44 projectors). Before we opened they would get BSOD's pretty frequently because the compartments that held the computers had absolutely no ventilation. The problem was solved by widening the openings. I feel bad for the guys who maintain the system, it has to be a nightmare... but they pull it off.
Err...If an appplication is already running you aren't going to get UAC prompts for it. Do you even know how UAC works?
Hey buddy I'm a MS fan myself. Laugh a little :p
I was just joking around.
