variable speed?????????
Sig
So I recently got an Antec 430 PSU. I've noticed since I put it in that the noise coming from the case gets much louder if I load up the CPU with prime95, like things are speeding up. Is this possible or am I on crack? :confused:
The fans are thermally controlled, so yes, prime95 is making your CPU give off more heat. Or you could just be hearing things ;)
