officermartinez
- Jan 21, 2006
Hey guys.. I am about to embark on a new setup. For those who are very familiar with the vapochill LS, I need some input. I pretty much have everything I need to swap my setup over from a watercooled system to a vapochilled system. Here is my current hardware and goal..
1. Intel QX6700. It's overclocked to 3.2ghz right now. Runs fine.
2. XFX 680i LT motherboard. No FSB issues on my quad like I encountered with my IN9 32x-max.
3. 4 gigs of Corsair Dominator 8500C5D ram.
4. Enermax Galaxy 1000 PSU.
5. 8800GTS video card.
My goals.. I would like to achieve a 24/7 stable overclock @ 4ghz. The visual appearance of my setup is one of my top priorities. I DO NOT want to chop here, saw there, dremel this, cut that, etc.. Also, I would like everything to be "self contained".. The moment I saw the Lian Li pc-343b, I knew this was the case for me. I would like to mount the Vapochill unit inside the Lian Li case. Furtermore, I would be mounting my triple rad inside the Lian Li as well. In doing some research, I am finding it hard to see if the measurements are even possible.. One obsticle seems to be the lenth of the hose, coming out of the vapochill unit.
On one side of the Lian Li case, I would mount the motherboard..
On the other side of the case, I would mount the Vapochill LS..
Would there be a way to mount the Vapochill LS inside the Lian Li without having to remove the outer Vapochill case? Would the hose reach over the top, where it would be mounted to the processor? If not, what about that opening towards the front part of the case? Is there a way to order a longer hose?
I would like the end result to look something like this (except the grills would be on the right side.. not the left side):
I still intend on watercooling my GPU(s). I generally never ask for help on stuff like this but since I am a total newb to Vapochilling, what better peeps to ask than some extreme cooling [H]ard|Forum members! Any suggestions? Is it even possible?
