Vantec Aeroflow?
Karandras
Good? Bad? I don't see many posts or reviews on it. The reviews I have seen have been alright but has anyone used one with good or bad results? I'm using one right now, temps are alright but not great. When I put the voltage up to 1.75 my temps jumped 10 degrees easy...and that was idle :-/ Load was like 60ish.
However, the airflow in my 3 year old case is not the greatest thing in the world and needs to be worked on. I could probably drop my temps by at last 5-10 degrees if I was to actually work on the airflow ;-)
I am running a Vantec Aeroflowin my current system.
It has been keeping my temps low.
I have a 2.4C @ 3.2 currently at load temps are at about 58 under load.
so I would say it's a good fan. But also I must say that the only other one I have tried has been the stock heatsink. And I couldn't get any overclocking action going on because of high temps. I was getting around 55 load. So I think it is a good fan.
I have a Vantec Aeroflow,
on an amd system.
1800+ @1.95v 204x12
Idle 51ºC
Full 55ºC
Rocks hardcore on an amd system.
happy with mine.... at 3.6Ghz it runs at 64C underload.(prime)
Lately I've been running at 3.45Ghz since summer is coming (in New Orleans!) and its like 59C underload.
I'm running an Aeroflow at 70% on my system (note the IC7), and I get idle temps of 41-45 and load temps between 56-60 depending on ambient. The heatsink is almost completely silent at this speed. The IC7 inflates temps a bit.
I have one to and it has kept me in the 40's on my 2500 at stock speeds
Running one on my 2500+ and idle temps are around 36-38 load is about 43-45. The sound can be annoying, but you get used to it.
My temps are about the same as the above post, running 24/7 with an AMD 1100 @ 1485. running folding at home the temps are at 43 - 46 I also added a 90mm fan at 7v to provide air to the area of the Aeroflow, and have a 90mm blow hole to allow the excess hot air to flow out of the computer.
It is louder than my other two computers, but alot quieter than the 60mm screamer that was on there originlly, and you can't hear it anywhere else in the house.
Alright, good stuff then. For the $30 CDN I paid for it, I got pretty good. I just thought my temps were high, I guess its just the Barton core that runs damn hot. Thanks all!
