The Dtek dye is really nice.
Thanks a lot. Are you putting the dye in water? or in a non conductive clear fluid?
I run a distilled water (1$ a gallon, can't be beat) + a few drops of iodine + some pentosin + D-Tek UV dye.
When you mix your coolant, do you just add those additional additives directly to the entire gallon of water? If not, how big of a water bottle or whatever do you think is big enough to fill a loop?
