on the wall...Originally posted by DeViLdUdE
Long.. where the f*ck is your comp mounted?? very nice UV tho.
If you want a nice looking sleeve go for the expandable sleeving it's time consuming not for lazy ppl but once done its all worth it.
And if you are really lazy hire a non english spokenin foreigner pay him 10 bucks and let him do it for you![]()
Originally posted by Highlife
I was thinking about sending it to Frozen, but dam they want ALOT for sleeving it. Like more then I paid for the PSU itself =).
The reason I want to stay away from sleeving it the time and the way i would have to do it. Also that very slim chance of messing up the wires and POOF! Another reason is I like to change my system every once in a while....different colors etc etc...if i sleeve it its pretty much on there for life unless I cut it off and sleeve it all over again. Also....I use some rounded cables, but for the ribbons like the one for my Live drive, it cannot be removed to be sleeved. Unless you want to cut about 60 little tiny IDE type lines. I round them off and tuck them in the loom, I want every cable to be the exact samething. No sleeved here and loomed there. Right now even my Primary IDE cable, which is rounded, is in wire loom.
Originally posted by JustLong
Sleeving doesn't take that long, I did mine in my spare time at work. The trick is buying a tool to remove the molex connector qucikly and to label where the wires connect to. With a little practice it might take a day to sleeve a psu.
Its easy to sleeve IDE type cable, just fold it at a 45 degree angle near the connector, then in half and half again, then slide the sleeving on and ziptie.
