UV Help!!
einsig
I need help with a proper UV lighting solution. I have two bright blue LED fans (rear and blowhole) in my Wavemaster case along with the blue tinted window. All my cabling is blue UV sensitive. I attempted to light the UV sensitive parts with UV LEDs as I find most CC tubes too bright. I wanted a deeper and more ambient light. Well I'll need about 10 of these 3-LED things to light half my case and that ain't happenin. Sooooo, here is my quesiton. Who makes a stable (no inverter issues) UV CC kit, preferably smaller than 12"? I want one that will really make my UV cables glow, but not fill the case with bright light. Thanks.
das ist toll, Ich habe eine techie toyz uv kit. Die techie toys uv kit machest!
That is a 4" sunbeam for way too much. I thought you used Techie Toyz?
Anyway, how effective will a UV light be with 2 blue LED fans already lighting up the case? The UV Laser LEDs I already have in aren't doing much. I'm not wondering if it is the UV LED it self or that the case is mildly lit. Hmmmm.
Cool. So it does work. Man That Laser LED I got is total ass. I'm getting a good cc tomorrow! Thanks.
Originally posted by Marc113-
Yes I did. And I changed all the connectors to UV green.
I just spent the evening doing just that. Sleeved EVERYTHING with blue Techflex and shrink wrapped the ends. Replaced a few of my connectors...just the ones you see for now. Too much of a pain to do the rest tonight. It makes such a difference doesn't it?
