Using UV Paint help
n64man120
How careful do you need to be with UV paint and where can you not put it? I want to spray it on my ram heatsinks, would this be ok?
it depends if that paints electrically conductive
you can spray it on the heatsinks but for best shot, dont spray the bottom of the heatsink where it goes on the ram chips... and make sure nothing is touching anything electrical... but then again, ur heatsink is probably conductive so i guess its ok
just spray it at places it wont be touched and you'll be fine
