flopticalcube
- Oct 2, 2011
I am thinking about building a compact gaming rig for my daughter (to replace her iMac) and was considering a Rosewill V3+ case. Its a cube design with the PSU sitting over the CPU and giving only 80mm of cooler height. If I use the PSU intake fan as a pull fan I have (just) enough room to add a 27-40mm AIO radiator underneath. I was thinking of replacing the PSU fan with a 4 pin PWM and letting the motherboard header or AIO control it. Depending on the model I could probably fit a 140mm rad in there. Has anyone got experience with a setup like this? Any thoughts on this at all are welcome. This will be a long term (1yr probably) build.
