Some users have recently had their accounts hijacked. It seems that the now defunct EVGA forums might have compromised your password there and seems many are using the same PW here. We would suggest you UPDATE YOUR PASSWORD and TURN ON 2FA for your account here to further secure it. None of the compromised accounts had 2FA turned on.
hi all, i'd like to use a projector for my entertainment needs, ie use it for TV, movies and video games...how would i go about setting it up? particularly the tv part, and sound?
well, youve generally got a choice of two input types - vga or svideo/composite.
If you want to run vga from a computer, youll need a tvcard on the computer, and dvd drive etc.
if you just want to use svideo/composite/component, for tv youll need a tv tuner (VCR is probably the cheapest way to get one). and probably some kind of switcher so you can hook up a game system. Any audio a projector has would be crappy. Youd just run audio through a home theater receiver. possibly video too, for the switching capability.
