[CoF] ATOMIC
- Oct 6, 2004
Greetings!
Since I recently replaced all my Coolermaster case fans with Antec fans (which offer more CFM at the cost of dBA) I have decied to run some temperature/wattage tests with our favourite tools of the trade: Prime95 and ATITool. Essentially, I wanted to see if the newly replaced fans added any sort of lowered-temperature-benefit or not. That and I wanted to get the general idea of how much wattage was being used during the full load test, which was achieved by using APC UPS PowerChute Personal Edition.
Last but not least, I have made slight modifications to my Lian-Li V2100b case. Simply put, I added an intake fan over the CPU/RAM region and an exhaust fan for the 7800GTXs to collect all the heat that those two bad boys produce. To finish off the mod, I added some fancy grills which I got from bigfootcomputers.com. The idea behind the grills was to make the intake/exhaust fans that much more stealthy lookin.
After doing all my best to tidy up the wire disaster I had in this case, I sat down and counted how much more CFM all those added fans gave me. So i turns out that:
15.9 x 2 = 31.8 (VGA Cooler)
34.0 x 2 = 68.0 (80mm)
79.0 x 6 = 474 (120mm)
114 x 1 = 114 (CPU Fan)
= TOTAL of 687.8CFM.
Which is a lil EXCESSIVE
, but I love going overboard at the cost of having a jet engine sound 24/7 coming from your Lian-Li case.
Just kidding, it's not that bad. Not as bad as the 8000RPM delta I had on my AhtlonXP in the other rig. That thing was ridiculous.
But anyways, now for some pics:
So what do you guys think? Decent temperatures or do I still need some serious cable managment classes?
How about your CFM total amount in your rig? Is it anywhere near as high as mine or am I just one crazy bastard?
So why would anyone want soo much airflow?
Well obviously to O/C this slut to unprecedented heights if the proc/RAM allows it. Something tells met that this will not be the case but it's worth a try.
I mean, I've spent so much time on getting so much air flowing in this case I might as well give er tits
2.6GHz anyone, or highly unlikely?
