I use a usb wifi dongle. Got 3 of these free for each PC when I went from DSL to Uverse.
It got much better reception than the wifi card in my PC.
My router is G only, might upgrade to N soon.
But for now does it matter where you plug in the wifi adapter?
Here are my options.
Front of case (USB is connected to mobo via cable)
USB hub (connected to mobo via mini USB)
Straight into mobo on back of case
I've tried doing some speedtest runs and frankly I cant get an accurate answer since my connection will range from 20ms to 45 ms each time I try it with the same USB connection. I could get an average, that would probably tell me but that'll take a while to compile data.
