Usefull calibration images ?
HiCZoK
Hi guys. I want to calibrate contrast/brightness and colors on my 226bw for which i have pc on DVI slot and x360 on vga slot.
I would be greatefull if someone would advise or share some good calibration Images so I could have the image shown on both inputs (pc and 360) and set it to look as equal to each other and real as possible with this setting :)
I couldnt find anything good enough on google images So if You could post some trusted and tested calibration images I woul be thankfull!
i have the same, but if it's C panel cannot be calibrated. it's just horrible, unfortunately...
just set it in Dynamic Contrast and leave it so.
oh man thats great!
I am on the sharpness test right now. I didnt even know it was so off by default on this monitor!
Great site. Can it quality be trusted enough that I should use this tests to calibrate my screens for good?
My image is significantly better after calibration with that site.
I am tho still considering gamma 1, 2 or 3 option on 226bw... and I am still thinking about difference between:
"Single-page version
If you already know how to use these images. "
"Without sRGB profiles
All images, but with the color profiles stripped, in case you want to see the effect of your OS color management. "
But I am just using standard insite images becouse I dont have any nvidia profiles as I understand it :)
