Usb2
DlStreamnet
I just rebuilt my pc to clean it out, plugged the case usb ports into the pins and they are only working on 1.1 usb, not 2.0. Do you guys know how to put it upto usb 2.0 again?
thanks
sp2, msi k8n neo4 platinum sli, winxp home
Bumping because I have the same problem. I've tried removing the usb root hubs and reinstalling drivers, along with flashing to the latest BIOS.
Does anyone have the mojo to make this silly thing work? The ole external hard drive running at usb 1.1 speed sucks.
this is, odd, I have done the same exact thing you have done before, but it never went to 2.0.
I am sure you have gone into BIOS, advanced opts to settle it?
if not then go into BIOS and make sure you have the right BIOS settings.
if that doesn't help, go to device manager and see if it is reporting anything.
