So I wanted to put a quickcam up in my house somewhere. I bought 2 USB 2.0 active repeater cables at 15 ft each. After all I've read about being able to run these as far as 80', I figured I'd have no problem. So, I plug in the first one, and then plug in the camera to make sure it works. Works fine. I plug in the second one to the first one, and it says that an unknown device has been connected and there is an error installing it. So I unplug the second cable and plug it into the back of the computer, along with the first cable. I try the camera in both and have no problems, so I'm sure it's not a cable malfunction. SO I try to plug the second cable back into the first, and I get the same error. It seems that windows doesn't like the second cable being plugged into the first.
Has anyone else had this problem? Am I missing something? Help please? Anybody?!
