USB Flash Drive Problem (Win764)
Silvers24
So, I have these USB Flash Drives, Sony Mirco's.
And I use them a lot. Well the 2 GB I use a lot, the 8 GB, only when needed.
So I transfer some stuff to the 8 GB yesterday, and when I plug it into this computer.
It like, turned my display off, so I had to hard reboot the computer.
All seems fine, so I try it again....well, it won't pull up. Nothing is wrong with the drive.
My PS3 picks it up just fine, and Windows 7 DOES pick it up, under Device Managment and shit.
But I can't access it, at all. It only shows as storage device, but the computer reads it, windows won't.
I've googled a shitload on this, and nothing works. How is it read, but won't let me access the drive? The 2GB pulls up just fine. But the 8 won't pull up no matter what but other then it's noticed.
When I plug it in, you can hear the noise it makes when a USB is connected, and when you disconnect it, the same thing. Even under the USB devices it shows.
So what gives?
