nonsequitur
- Feb 13, 2002
my office pc doesn't have any usb ports readily available, however, i did recieve a usb extension cord of sorts with a usb thumb drive once upon a time.
i table tied this extension cord so that it fastens to my keyboard tray, and it worked well with the usb thumb drive, and it saved me from having to get under my desk just to attach the drive.
now i'm trying to sync an ipaq by plugging into the extended usb port, and ms active sync will not recognize the ipaq. it will sync when i plug the sync cable directly into the workstation.
interestingly enough, the ipaq turns on when plugged into the extended cable, but does not begin charging or begin a sync (so i know *some* signal is getting though).
does anyone think it's worth getting another extension cable, or just f* it and get a usb hub?
