- Apr 9, 2002
I just picked up a Lexar JumpDrive Secure USB drive (512mb) from office max for $30 bucks.. did i get a good deal? Also, is this a good USB drive???
rebelleader said:YES!!!!! YES!!!!! YES!!!!
I just bought the same one about 3 months ago on a whim from Target and paid $75. I didnt shop around at all for it. I saw it, I wanted it, I bought it.
I really like it the only problem is that it is slightly too thick. Sometimes it can partially obscure a neighboring USB port and on a computer at work a serial port gets in the way also.
I found two good programs that you can run from the drive. One is portable firefox(for web browsing), and the other is portable thunderbird(for email). Doing a qick google search can bring you to the sites for the programs.
You should be very happy with the drive.
robberbaron said:You can also run Windows 98 from it, as long as you know how to trim it down to only the necessary features.
