Usb 2.0
maXXspeed
is there a way to check and see if my USB is running at 2.0?
im using the D - bracket that came with my K7N2 delta L.
i also have usb 1.1 and 2.0 enabled in bios.
thanks
maXX
I plug my USB 2.0 Thumbdrive in. If I get the message telling me a high speed device is in a non-high speed port, than I know I need to install the drivers yet.
Well, you could try the old fashioned way, stick a USB device in there and try to transfer a large file, you'll be able to tell if it's 2.0 or not if you've ever used it before.
