Hi guys,
I know it's not exactly an OS question but i'm freaked out and need help.
As some of you may know I installed Vista HP and my HDD where I had backed up all my files was formated as dynamic (YES i know! let's drop this right now) so i couldn't/can't access it.
So anyway I was afraid to use the dskprobe thing straight away for fear it would mess things up (I have a lot of important docs on this drive like wedding files and such :/)
So I got Recover My Files and ran the fast recovery thing (which is supposed to take 20 minutes but on my drive took 4 hours)
with this I was able to save my first partition on the drive which had my game saves but the others wouldn't show.
So I ran the complete file recovery which took a mighty 80 Hours! (which the support people told me was way too long and not normal....)
anyway i ran it and at the end all my files seemed to be there and I started saving them on my drive but they are all corrupted!
I tried doc, txt, mp3, pdf..........nothing works!
The HDD is 1 week old! and was working perfectly before I installed my new rig and Vista.
I'm really starting to get scared I won't be able to save ANYthing......
I'm thinking about buying a rack to make the HDD external and try to read it on a bunch of computers that have XP.
or scrap Vista and reinstall XP, or make a dual boot with XP to see if I can still get the files.
do you guys have any suggestions?
