exchange keys
- Feb 18, 2009
NOTE: I wasn't sure where to post this, so if there is a different forum for my type of question, please move thread accordingly.
We have a market research company that uses Confirmit to create/design surveys. Whenever the end user wants to export any data from it, the data gets compiled as a SSS file (which really is a XML file). This SSS/XML file has the schema of how the data should be manipulated and presented.
Sample of SSS/XML file:
I was wondering if the end user(s) could just "import" XML files into a database (MS SQL 2005) so they could keep track of trending data.
Anyone ever had any experience with doing something like this?
Thank you for your time.
Code:
<?xml version="1.0" encoding="utf-8"?>
<sss version="1.1">
<date>14 6 2011</date>
<time>12:15</time>
<origin>Confirmit Export</origin>
<user>username</user>
<survey>
<title>Survey Title Here</title>
<record ident="A">
<variable ident="1" type="quantity">
<name>responseid</name>
<label>responseid</label>
<position start="1" finish="8" />
<values>
<range from="1" to="99999999" />
</values>
</variable>
<variable ident="2" type="quantity">
<name>respid</name>
<label>respid</label>
<position start="9" finish="16" />
<values>
</values>
</variable>
</record>
</survey>
</sss>
