Some users have recently had their accounts hijacked. It seems that the now defunct EVGA forums might have compromised your password there and seems many are using the same PW here. We would suggest you UPDATE YOUR PASSWORD and TURN ON 2FA for your account here to further secure it. None of the compromised accounts had 2FA turned on.
I have an Asus Pundit P1-PH1 and want to upgrade the power supply. The current PS is 250w and would like to upgrade to a 300-350w. It's a P4, 24-pin mainboard, need molex, and SATA. I'm having some problems finding ones that will fit. The dimensions are 4.75"L x 4.75"W x 3"D (121mm x 121mm x 76mm). I can't go any bigger dimension wise for space reasons. Thanks in advance.
