Hey all,
Time for an upgrade (current build at the end of this post)!
I built my current SFF rig with the help of you all a few years back and I feel like it's time for an upgrade. I'm looking for more input (and expertise) and I am open to ALL and ANY suggestions. So if I need a new MB/CPU/etc... please do not hesitate to say so!
1. What will you be doing with this PC?
1080p gaming while being able to live stream (Twitch) with 60fps.
2. What's your budget? Are tax and shipping included in this budget? Is your budget flexible? Is cost a driving factor in component selection?
I'd love to be able to keep this upgrade at under $500. Tax and shipping are NOT included in this budget. Budget is flexible. Cost is NOT a driving factor, performance is.
3. Where do you live? Do you have any big B&M (brick and mortar) computer chains nearby (e.g. Microcenter, Fry's, etc)?
Live in Cambridge MA
There is a Microcenter very close to me
4. What exact parts do you need for that budget? CPU, RAM, case, etc. The word "Everything" is not a valid answer. Please list out all the parts you'll need.
This is exactly what I'm trying to figure out and turning to you all for input but I am assuming I will need:
GPU
SSD
RAM (?)
5. If reusing any parts, what parts will you be reusing? Please be especially specific about the power supply. For reused parts, list brands, model #s, and, if applicable, firmware revisions.
I would like to keep the MB/CPU/Heatsink/Case/PSU however I am open to all suggestions:
MB: GIGABYTE GA-H67N-USB3-B3
CPU: Intel Core i5-2500K Sandy Bridge
CPU Heatsink: Thermalright AXP 140
CASE: LIAN LI PC-Q11B
PSU: SILVERSTONE Strider Plus ST50F-P PLUS BRONZE Certified Modular Active PFC Power Supply
PSU cable: Silverstone Short Cable Set For Silverstone Strider Series Modular PSU Model PP05
6. What specific features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? USB 3.0? SATA 6Gb/s? etc. Which is more important, size of the system or having the particular feature? Make sure you indicate *required* vs. *wanted* for each feature you list.
Most important is size; trying to keep things small, portable and unobtrusive.
7. What resolution output do you need? 1080p, 720p, DVD quality, etc for HTPC or list Vertical/horizontal resolution for non-HTPC SFF rigs. Do you need multiple monitor output?
Single monitor 1080p. Don't need multiple monitor output for gaming but will need for daily activities.
8. Does this system need to fit into a particular space? Think entertainment center shelves, closet space, rackmount, etc.
No.
9. How comfortable are you with custom case design/modification and electrical wiring? What tools do you have (Screwdrivers/Leatherman, Drill, Dremel, Metal snips, Soldering Iron, Bending Brake, CNC/Welding machines/Plasma cutter, etc...)?
I built my first SFF rig here with your help and things have run fine. Ive never custom designed or modded. I feel confident I can do so with proper instructions. I know how to solder but have only done so with basic electronics like radios and headphones. I have access to most home improvement tools (hammer, screwdriver, drill, metal snips, wire cutters/strippers, etc...), could probably get my hands on a dremel if need be.
10. How important is the noise/silence of this sytem? HTPCs typically want to be quiet while all-out SFF gaming rigs don't care
I am happy with the noise/silence of my current build.
11. How mobile does this system need to be? Need a carrying handle or carrying straps? Is weight important (carry-on bag, etc)? Water cooling quick disconnects, etc?
I currently move my case around with ease and would like to maintain it as so.
12. Do you already have a legit and reusable/transferable OS key/license? If yes, what OS? Is it 32bit or 64bit? Remember that OEM copies of Win7 have issues with new motherboards
Yes. Win 7 home sp1 64bit OEM.
13. When do you plan on building/buying the PC? Immediately, in a couple weeks, 3-5 years?
I would like to buy and build within the next week. My deadline to have all parts in is March 6th 2015.
Here is my current build which I am looking to upgrade:
RAM: CORSAIR Vengeance 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Low Profile
HDD: SAMSUNG Spinpoint F3 HD103SJ 1TB 7200 RPM
ODD: None
GPU: EVGA 01G-P3-1373-AR GeForce GTX 460 (Fermi) Superclocked EE 1GB
GPU
SSD
RAM (?)
No.
ODD: None
