upgrade case?
mpegripper
i have a cooler master case which has one 80mm top exhaust and one 80mm back exhaust
should i upgrade to a lian-li pc60 or pc-65?
am i going to see a huge difference with the 2 front intakes?
i think i would, just not sure
i'm using 28cfm fans, currently vantec, but want to move to silenx
also, any good recommendations of cases that might have 92 or 120mm fans?
and what's the difference between the pc-60 and pc-65
TIA
do you actually need extra fans? are you ocing sth? there are couple cases that can accomodate 120mm fans, like Antec Sonata...
you could always mod more fans into your computer... it'll save you money and give you something to do...
