hey all
i got a wmp600n adapter and the stock antenna's dont work to well specially due to the fact that they are in the back area of my entertainment cent and surrounded by power, audio, and data cables.
I have never bought antennas before and wanted to know what would be a good option, i was thinking a small table top one with a long wire so i can move the antenna away from that area, maby on top on the entertainment center, but would the wire to the antenna need to be shielded?
my problem is low signal and it stutters during the play back of a 350 mb 40 min long video.
i have connected with the 5ghz N and 2.4 ghz g and i have low signal and stutter with bolth however browsing the web or copying files works fine.
my router is upstairs and it is a wrt610n
before i installed the wmp600n i was using a old g based router with dd-wrt as a client connected to the computer with a lan cable, and that provided perfect play back even with a 12gig 720p movie.
any ways, could ya all please gimme some good recommendations on replacement antennas for the adaptor.
i have now idea at all about them like does a 10 dbi antenna need more power then the stock 2dbi, can i put a higher dbi antenna on this card or does it need to be stock, ect...
Thanks
bob
Thanks
bob
