dinofx35 said:I've realized a potential issue with interpreting the PWM signal. In my Shuttle XPC, the PWM signal is roughly a constant 4.25 volts when the duty is 100%. (And, of course 0 volts at 0% duty). I measured this a while back during the breadboard stage, I used a 100K resistor and a .1u capacitor as an RC filter, and just plugged it into a spare FAN header and set it to 100% with speedfan.
Is there any reason to think that this value is the same for all motherboards? I'm going to guess that there is a very good chance that a single pull-up transistor is being used here to pull up to +5V. The 0.8V difference seems suspiciously like the voltage drop across a transistor.
Is there anyone out there with a voltmeter and a PWM Fan header on their MB willing to measure their 100% duty voltage? Or, does anyone have information suggesting that PWM signals are between 0 and <5 volts?
Sounds like board revision timedinofx35 said:True, if I were interpreting it as a "digital" signal. But, I'm treating it as analog using an RC filter. I think this is not going to be a problem since fan manufacturers require the signal to be at least 2 volts, and I doubt it would be more than 5.
