I have a small Via EPIA 500Mhz computer that I would like to use as an untangle box. Problem is, it only has one NIC onboard. I need two NICs for my plan to work. There is no space in the case for a PCI card. Are there any USB NICs that are compatible with Untangle?
Any suggestions? I want a small computer to put in my wiring closet with everything. I have FiOS but HATE the router that it comes with. So I'm going to set the router to just be a modem and use untangle for QoS and other advanced features.
