Just wondering if anyone else has run into this.
I've attempted to download untangle for home use -- the Re-Router version for XP. I go to untanlge.com and follow the links for downloading. I've also tried the two available exe's from sourceforge.net. All of the things I've downloaded fail while trying to verify the installer. I know there is a way to get around and continue with the install even if it fails the integrity check.
One odd thing is, is that I've downloaded the exe's from work now -- tested them on an XP machine there (and they passed the integrity check) -- and copied them to my home machine. Same thing -- they fail!
What would possibly be causing this? Same AV on my home machine and test work machine. I find this kind of odd -- and irritating!
