Well I'll have to check if that motherboard will work with Untangle.I "think" I read something about Intels Atom board which required a workaround installing an earlier version of Untangle over on Untangles forums...may want to do a search over there and check on their hardware compat list in the Wiki. I'd guess it runs smoothly on the newer version of Untangle though...they really increased the hardware compat with versions 7.3 and current release of 7.4.
All I can say is on the SuperMicro D510 board that I used and linked...7.3 went on smoothly (whatever subversion was out 2x weeks ago, 7.4 was just released. There is a less expensive version of that SM board on Newegg that has a similar part number....minus the "O" or something..because it doesn't have the IPMI remote management module..it's about 60 bucks less.
I don't have pics of the unit...when I get it all installed in my 12U comm cabinet I'll post some..but with Neweggs picture views on their pages...you can see them from many angles.
I priced out an untangle box for $220 on Newegg
http://www.newegg.com/Product/Product.aspx?Item=N82E16813121399
http://www.newegg.com/Product/Product.aspx?Item=N82E16811234033
http://www.newegg.com/Product/Product.aspx?Item=N82E16820148163
http://www.newegg.com/Product/Product.aspx?Item=N82E16822148511
http://www.newegg.com/Product/Product.aspx?Item=N82E16833106122
I've been running Astaro on it for over a week now, like Untangle, it also installed flawlessly and runs great.....probably be getting PFSense on her soon.
That's new to me... is it open source?
Intel NIC's are the best, Broadcom are decent too, Realtek are shit.
Keep in mind though, that there are plenty of dual head intel NIC's out there that can be had for pretty much any slot. Just in case you land on a sweet as hell deal on a board with Realshit NIC onboard.
Scroll down to post 96 in this thread, I got that gear and had Untangle on it for a bit, ran just fine.
http://hardforum.com/showthread.php?t=1528968&page=5
It's a D510 Atom, dual core.
Yes the 410 and earlier Atoms will do for a home setup with just a PC or a couple....performance will depend on what you do with it. If you're a heavy downloader..you may find you tax the Atoms a bit. But for average web use the dual cores do fine.
The 1U chassis I got is also in the above link, is an relatively unknown one that Supermicro makes...it's a front I/O model which IMO is better.
Also the hard drive I got in the above link, is a low heat low energy consumption model which is ideal for DVRs and firewalls and stuff like that.
If you happen to be a heavier internet user and are worried that the Atom isn't enough nut for you...Supermicro also has some motherboards which fit that short 1U chassis just fine..that take dual core/core 2 duo/xeons.
Today i totally put a load on my P4 2.3 with 2 gigs ram, that beast got HOT! she was over working for sure.
I can see that untangle sure takes some, power to run.! Good thing my new box is being built tomorrow.!
What all did you have running on it to put on the load?
That's hardly a load. The torrents put some on it, windows update was really nothing..that's just http to one source.
Get 50 people surfing different sites, several of those users watching youtube, a mail server with lots of SMTP traffic coming it...now you're talking about starting to put a load on it.
What was your CPU load? I don't recall a P4 2.3GHz.
I doubt you could get her to reach 1.0 on the CPU load from home. Downloading w/4-5 rigs can saturate your bandwidth pipe from your ISP, but it's still actually a light load for your router.
Here's a screenie from a client of mine, nursing home, HP Prolian DL320 G2..old old 1U rack mount server with a plain Pentium 2.26 in her..no Xeon. Just 1.2 gigs of RAM. It's on a 12 meg internet pipe, with approx 50 users on the network...many online with pharmaceutical portals, and I know there are a few Pandora and other online music listeners in the office.
She's a "weak" box horsepower wise...hopefully I'll close out the year before having to reboot her.
have also built a few NAS in those norco cases, depending on where it sits, i will rewire the case fans in it for 7v....
Might want to remove the URL in that screenshot.I doubt you could get her to reach 1.0 on the CPU load from home. Downloading w/4-5 rigs can saturate your bandwidth pipe from your ISP, but it's still actually a light load for your router.
She's a "weak" box horsepower wise...hopefully I'll close out the year before having to reboot her.![]()
i was going to try astaro, but i wanted av at the gateway, and astaro doesn't have that.
So it's untangle for me.
You said that about 2 weeks ago in another post..and several of us corrected it...
Yes it does have antivirus..matter of fact..it has 2 different ones. There are several different Astaro versions, and for home users....they have a FREE version that includes TWO antivirus engines..plus anti spyware...plus..many other things.
are the anti-virus features of astaro and untangle the only reasons you guys are using that over pfsense?
Anti Spyware modules have shown to also be quite effective...I have far less rogue/fake alert calls at clients that I have running behind Untangle.
As well as spam/virus filtering for e-mail servers.
I love PFSense also, it's my favorite for use at home...excellent QoS ensure the best online gaming I can have despite what others in my household are doing on their computers.
But for business networks...UTMs are a must these days, gone are the days of a plain old NAT router, business networks need additional layers of protection.
I really like those atom 510 boards but they only have the 2 nics. I couldn't find a cheap intel pci express nic to add.
Any ideas?
NICE uptime![]()
