1Wolf
- Jul 10, 2007
I'm swapping out an old Q6600 B3 for a new Q6600 G0, and while I'm at it...I'm considering swapping to a different cooler.
On the original Q6600 B3 I had in that machine, I was using the unlapped TRUE and got the following results:
Room Temp: 24C
Idle: Avg 39-42 per core
Load: Avg 52-55 per core
The TRUE always gave me two concerns:
1) The weight of the TRUE has always concerned me, and on more than one occassion I've had problems with the weight of it. I've had to fashion a 'suspender' for it to help support it.
2) Most user reports/reviews I read suggest lapping it and I haven't lapped mine.
I also have a ZEROtherm Nirvana.
What do you guys think I'll be better off with....an unlapped TRUE or ZEROtherm Nirvana?
The TRUE is 'generally' seems to be accepted as one of the best performing air coolers. However, I prefer not to do any lapping of the CPU Heat Spreader or the Heatsink...I'm still a novice at this and don't trust myself not to make it any worse than it might be from the factory. The ZEROtherm shouldn't require any lapping.
Q6600 is running at stock speed right now, but I will be overclocking it.
Room Temp: 24C
