Some users have recently had their accounts hijacked. It seems that the now defunct EVGA forums might have compromised your password there and seems many are using the same PW here. We would suggest you UPDATE YOUR PASSWORD and TURN ON 2FA for your account here to further secure it. None of the compromised accounts had 2FA turned on.
When my CPU runs load or anything close to 50% my 12v drops from 11.920 to 11.630-11.730 ish. Is that bad? it will go up and down the more or less the CPU is used.
the CPU on modern mobos is powered off the +12V from the power supply (stepped down of course by the onboard VRM voltage reglation modual) older boards employed the +5V and so older PSUs are strong on the +5V and +3.3V rails (which are typically combined rails), so if you have an older supply, and your powering a newer mobo, it may not have enough Amps on the +12V rail for everything, in the last 2 formfactor spec upgrades for power supplies the +12V line has nearly doubled
where a 400watt "typically" used to have 15A
now they have closer to 22 > 34A
(actually they have dual +12V rails in the V1.3 and V2.0 spec)
so...your rails dropping could be because there is too much draw on that rail
