Ultra-90 AM2 compatible?
it comes in 2 verisons, one is lga 775, the other is k8...
so yeah, half of them will work :p
id like to add that a xp-90 is about 3-4 years old it seems.. and is overpriced for the performance it gives.. i have 4 of them so they arent that bad but i wouldnt pay more than 20$ shipped and partial reason for me getting them is they look cooler than teh stock heatsinks but they are really not that much better in performance unless 92mm high performance fan is used.. and then it is louUUUd
This is the ULTRA-90, so it has to be uber 1337 :p
ohhhhhhh i had a few of those also.. decent for 13$ shipped would get the freezer pro 7 instead
well it is cheap and might have that part at svc.com.. fuxors at svc.com barely speak english and hardly get your order right but its very cheap and nice layout..
svc.com has them for at most 15$ compared to newegg's 23+
svc also sells the screw down bracket kit for the cooler as well. I bought one to use on my tforce 550 and it works like a champ. worth the extra $8 or so it was. I despise the damned lever-type brackets.
PLEASE link me :p
Yeah, I don't really have to worry about heat now as my Brisbane is @2.7 with stock volts, but want to see what this bad boy WILL do. Using AC Alpine 7 now.
Oh. I wasn't aware they're so cheap. Plus, I had XP-90 on my mind, not the Ultra-90, I apologize to all. Ultra-90 is ok.
