For 2x the price?theseeker said:Lian-Li V2000 works very well.
Ratboy said:For 2x the price?
Don't you use 1/4" tubing?theseeker said:If one wishes to cool, one might as well go all out.
isnt MM paint jobs supposed to be total shit?ikellensbro said:Perfect (sensible) WC case: GigaByte Aurora with stock room for a 2x120mm radiator and hole for tubing to go to external components.
Absolute best if you've got the room & money: Mountain Mods U2-UFO with 7eek:!) 120mm fan mounts and the room of two cases for holding everything you could possibly want. U2-UFO=dream
Here we go again...jtobrien said:isnt MM paint jobs supposed to be total shit?
lol I know what you mean. Looks like the sound effect fonts in the comics. "POW!" "BAM!" "WAP!" "THUD!"m0unds said:just as an aside..in the newegg images for the server case, the text on the box that says "SERVER CASE" is really funny. i don't know why.
Ratboy said:This I-Star looks like it has a lot more room to work with. I planned on modding the case a whole lot as well, including a double radiator on the top and installing a window myself. There are enough 5.25 bays to mount a 2x 5.25 reservoir, 4x HDD's with water blocks, and an optical drive with no drive cage in front of the bottom 120mm intake fan, were I could use that space for the pump. All that and still have 2 5.25 bays left over. I'm thinking a 2x 5.25 LCD screen there to monitor temps.
Ratboy said:Don't you use 1/4" tubing?![]()
Mickey21 said:Here we go again...
Paint = wrong, Anodized = correct
Total shit = wrong, Durable finish that outlasts anything you can shake at it for $50 or less = correct
Have to get the case "painted" = wrong, Available anodized option if desired = correct
How many times we gonna hear this? If you dont own one, dont speculate, if you dont know, research the matter... If you still insist on spewing others opinions, state so (ie I heard from a person from a person who heard in a chat room, that the painting on the available cases from MM might not be up to snuff. Make sure you check it out before you buy I reccomend) That should be your comment... Be objective fellas, not spurting out negative comments you know nothing about...
/end rant...
altec said:128 bucks? no way. Your better off getting the chenming \/
http://www.newegg.com/Product/Product.asp?Item=N82E16811125468
I-STARDimensions 8.1" x 26.4" x 18.6" (WxHxD)
Dimensions 8.7" x 17.8" x 26.8"
All you need for a pump is a simple Swiftech MCP655/Laing D5, or even the tiny MPC350/Laing DDC, 12 volt pumps with higher head than most computer water cooling pumps out on the market.Scubastevie00 said:Like what was said before though. You need a serious pump if your going to watercool with that thing. Unless you run really close lines and keep everything low. But I doubt most people are going to do that.
8MM, and your point is?Ratboy said:Don't you use 1/4" tubing?![]()
Really, I don't see a problem with a heater core on the front of the UFO. Took ZERO mods for my install..................Scubastevie00 said:Yeah and my heatercore barely fit along the front panel in that case... You can't put hd's in the normal spots if you use the dual...
The I-Star has 177+ more cubic inches.altec said:Chenming
I-STAR
Now what?![]()
Down, man. It was just a joke. My plan was to have 2 loops, one 1/4" and one 1/2".theseeker said:8MM, and your point is?
Any suggestions?Scubastevie00 said:Like what was said before though. You need a serious pump if your going to watercool with that thing. Unless you run really close lines and keep everything low. But I doubt most people are going to do that.
