Its water that doesn't get stuff wet?
http://abclocal.go.com/wpvi/news/04132004_slide_sapphire/04122004_image_tankwide.html
Originally posted by maxkilling
that looks interresting
Think PURE h20 still conducts,, I could be wrong.
So it has to be something else then H20.
[i]Boiling Point @ 1 atm 49.2°C (120.6°F)
Specific Heat,Liquid 1.103 kJ/kg°C (0.2634 BTU/lb°F)
Specific Heat,Vapor @ 1 atm 0.891 kJ/kg°C (0.2127 BTU/lb°F)
Liquid Viscosity @ 0°C/25°C 0.56/0.39 centistokes[/i]
Freezing Point -108.0°C (-162.4°F)
Critical Temperature 168.7°C (335.6°F)
Critical Pressure 18.65 bar (270.44 psi)
Critical Volume 494.5 cc/mole (0.0251 ft3/lbm)
Critical Density 639.1 kg/m3 (39.91 lbm/ft3)
Density, Sat. Liquid 1.60 g/ml (99.9 lbm/ft3)
Density, Gas @ 1 atm 0.0136 g/ml (0.851 lbm/ft3)
Specific Volume,Gas @ 1 atm 0.0733 m3/kg (1.175 ft3/lb)
Vapor Pressure 0.404 bar (5.85 psig)
Heat of Vaporization @ boiling point 88.0 kJ/kg (37.9 BTU/lb)
Solubility of Water in Novec 1230 Fluid <0.001 % by wt.
Relative Dielectric Strength, 1 atm (N2=1.0) 2.3
