UD5H bios updating problem--Qflash
Rustic
Im trying to update to F7 bios and ive got my thumb drive with the file on it. When i go to the Qflash screen i cannot select Update from Drive. its like my enter button and my double left click will not work to select it.
Should i try @bios instead?
What is the size (capacity) of the particular thumb drive that your BIOS file is on? If it's greater than 32GB, chances are that it has been formatted with NTFS instead of FAT32. QFlash does not support NTFS-formatted media at this time; QFlash recognizes only FAT or FAT32 formatted removable media.
Or, if that thumb drive is 32GB or smaller, did you manually reformat it as NTFS or exFAT? If so, that could have been the culprit.
This and also make sure you are using usb2 ports, not the usb3 ports. The usb2 port are most offen native while usb3 ports may go thru a seperate chip and need drivers.
That I forgot to mention. This situation is commonly the result of having a relatively new case that has USB 3.0 ports in front, and that those ports are connected to a USB 3.0 header on the mobo (which is controlled by a third-party controller on most boards). If this is the case, the OP will have to reach all the way to the rear of the case to access the USB 2.0 ports unless the OP has a USB 2.0 hub connected to either a rear USB 2.0 port or an internal mobo USB 2.0 header. The only chipsets that have native USB 3.0 support are Intel's Z77/H77/Z75 chipsets and those AMD chipsets for the Fusion APUs.
its a 4gb capacity and i will try the usb 2.0 ports. thanks a bunch
sure enough, i put it in a red usb port in the back and it worked. thanks!!
