Two Loops, One Drain
You would need some type of Y or T fitting with valves. So, if you wanted to just drain one loop, you open that one valve and drain it.
You need 3 y or t fittings with a drain port. Basically each loop has a t-fitting that runs parallel. Those 2 connect to a third one which acts as a drain.
