Hello all,
I have two little questions
a)Where can you order those square push-in mounting bracket things for motherboard trays?
and
b) On a certain case I want to hack away on(Old case, just using the mobo tray), for the I/O port panel - The shield is held by some weird steel bit and and some screws, meaning that normal shields won't fit. I enclosed a picture, I was thinking if I dremel where the green is I could fit a normal shield in.
Pic:
and
Pic:
