Turtle Cage w/ rain
Daywin
So maybe this doesn't go here, lol, but it's kind of a case mod.
So turtles are most active during and after the rain, and I have had my turtle for 13 years now, he's just a friendly box turtle....
So he needed a bigger home, because turtles apparently need their privacy, so a good friend of mine help build me this wood cage..
I did caulk the edges pretty well and I just had to try this crap in a can that is flex seal.....always seen it and always wondered lol so I gave it a couple of coats with it
Next is fiber glass filler to build his pool and his terrain and to also slope to the drain because this thing is going to have rain (very fine mist) with the river rocks im hoping to build a filtered eco system for my turtle!
You'd better have a running rig inside that thing to keep your turtle warm, or I'm gonna cry "foul"!
A computer with a live turtle inside it? Very [H].
Be sure to make it a fanless system...
Anyway... I'm looking forward to see how this turns out.
Are you sure the flex seal isn't unhealthy for the turtle?
Uh you might want to at least screw a motherboard onto that if you want to keep this thread alive :p
General Mayhem has better spots for a thread like this.
Also, you forgot a pic of the turtle.
Haha yeah I'll put a pic up of Ralph. The pump will be here tomorrow and the fiberglass molding will start today, all of the flex seal will be covered up with fiberglass filler, but that stuff works really well on wood I'm not gonna lie, I didn't think it wood at all...(haha puns)
So I finished buying everything I needed last night, so as soon as I am off work it's building time!!!!
