tubing?
Main Target
i hear clear flex is the best? anything from frozen CPU that will work well for me? i dont see anything on that site and im ordering all of my stuff from there so i was hopiong theres something from there i can buy.
I believe that they sell Tygon if you don't mind paying an arm and a leg from Frozen CPU. Clearflex has similar propoties and costs half as much.
Frozencpu just sells Tygon and standard vinyl. Both are hideously overpriced from them. Id buy it somewhere else. Anywhere else. Tygon should be around 2.25-2.50 per foot and clearflex about 1.00-1.25 per foot from any place that isnt trying to screw u.
dangerden.com also sells tygon. about $2.30 a foot, i think.
clearflex is much cheaper and you get a discount if you buy 10 feet or more. :D
Try mcmaster.com, their tubing is dirt cheap, bends like Tygon and is very clear. It wouldn't surprise me if Tygon made it for them (OEM) This stuff is only .57 cents a foot for 1/2" ID x 3/4 OD tubing.
http://www.mcmaster.com/
Page 82.
