Hey guys,
I'm trying to hit a stable 4ghz on my i7 920 build. I'm running the following setup:
i7 920 D0 (MicroCenter batch)
Asus P6T (vanilla)
OCZ Gold 6GB 8-8-8-24
Antec 1200 Case
CoolerMaster V8 HSF
Current settings as follows:
Multi: 21
BCLK: 175
CPU VCore: 1.21875
PLL: Auto
QPI Volt: 1.25
VDimm: 1.64
Ram Timings: 8-8-8-24 (rest are set to auto)
IOH: Auto
ICH: Auto
HyperThreading: On
C1E: Disabled
CPU Spread Spectrum: Disabled
Execute Disable Bit: Disable
Turbo Mode: Disabled
SpeedStep: Disabled
Load Line Calibration: Enabled
(all other settings left on auto)
Currently the machine is running at 3675 mhz and has been Prime95 blend stable for the past 10 hours.
Also, it appears that 1.21875 is my stock VID. I found this by setting everything to auto, and going full load on Prime95, and checking CPU-Z. I then set my CPUVcore to this value and my BCLK to 133, and upped my BCLK by 10, tested, and repeated until 183. 183 appears to cause a BSOD when trying to run Prime95. (occurs about 20-30 seconds into starting a blend test with 8 threads) Therefore, I backed my BCLK back down to 175 (not 173) and so far it appears to be stable.
My question is - what value should I bump next to try and hit 4ghz? If I try bumping CPUV, it looks like that I still receive BSOD's. Should I try bumping QPI next?
Obviously I'm trying to do this with as low voltage as possible. (efficient overclock) I'm not too concerned about my temps at this point in time, but FWIW they are hovering around 65-70 right now. (CoolerMaster V8) I've read that a lot of people with D0's have been able to hit 4ghz with only 1.25 vcore. I followed a number of guides with published settings but didn't have much luck in those configs being stable. (However I could POST and boot into windows ok)
Any advice is greatly appreciated.Thanks in advance!
- Ace
Asus P6T (vanilla)
Antec 1200 Case
CoolerMaster V8 HSF
Multi: 21
BCLK: 175
CPU VCore: 1.21875
PLL: Auto
QPI Volt: 1.25
VDimm: 1.64
IOH: Auto
ICH: Auto
HyperThreading: On
C1E: Disabled
SpeedStep: Disabled
- Ace
