Some users have recently had their accounts hijacked. It seems that the now defunct EVGA forums might have compromised your password there and seems many are using the same PW here. We would suggest you UPDATE YOUR PASSWORD and TURN ON 2FA for your account here to further secure it. None of the compromised accounts had 2FA turned on.
If i were you, i'd just buy some EL wire and coil it around my cable, like so:
That is an IDE cable with a transparent encasing, with EL wire coiled under it, as you can see the encasing helps spread the light. You can buy one of those, or do it yourself-- you will need some transparent (or translucent) cable sleeving.
