I recently installed pfsense, and it's a generally default install. I played with a couple package installs and removed them, so there's the possibility of some lingering effects there that I didn't notice.
I used to have my dedicated TF2 server I'd use occasionally that worked fine with some port forwards on my old Dlink DGL4300.
Now with pfsense Im just getting around to trying to get one going for the halloween events going on in TF2 for the next couple weeks, and Im having absolutely no luck.
I found a number of threads discussing it and most stopped asking for help at specific steps which I took to mean they got it working.
First they port forwarded 27015 to the machine with the server on it, and then they created an outbound static port 27015 rule and most agreed it worked.
However, I can't get my server to see the master server...it doesn't say that it's connected to the master server. The information put in the console window on loading is not the same as all the reports of a properly working server, BUT I can see it and get onto it in the lan. So it's functional, just not getting out to the net.
When I try to access it by the outside address I get no response. It doesn't show up on the master list after hours of running. I just can't tell what the issue is due to my lack of knowledge on how to get around in pfsense and generally not running the server often enough to notice if this problem was there prior to the pfsense install or not. I want to say the server worked fine before pfsense, but I can't 100% guarantee that.
So, I am hoping someone out there has some knowledge on getting this straightened out...I've exhausted anything I can think of for search criteria to get the answers to the problem Im having.
Oh, and I did clear the states of the pfsense which was another thing people were suggesting to do...it had no effect on getting the server reporting to the master servers or accessing it via the outside address.
Obviously some kind of filtering is taking place, I just don't know what to look at for solutions.
Thanks.
Thanks.
