Hi,
I am updating a friends PC to Windows XP Home Edition. They are currently running Windows 98 SE which as far as I can tell, is so bugged it's not funny.
I was thinking of just upgrading to XP Home to see if that irons out all the bugs but from the XP setup, I keep getting errors.
For example, "The file D:\I386\mfc42.dll cannot be copied to C:\WINDOWS\Setup\mfc42.dll". This also happens with the file migisol.exe from the same directory.
I tried this a few times but kept getting the same errors so I decided against the upgrade as even though the installation continued, it stopped at a fatal error point and said to contact Microsoft. (Unless, someone can tell me how to fix this so I can go ahead with the installation)
So, I'm considering the new installation of XP Home on this PC in hope that it will wipe it clean and all the bugs with it.
Thing is, I know how to do but am not sure with getting the PC back to normal with drivers, etc, to get it and all the hardware back up and running.
The help I am asking for is if there is a guide or if someone can tell me what I should do before I do this new install. I read somewhere to get all drivers and burn them to CD, etc, and to also backup all the files I want to keep. I'm just not sure what I have to back up and which drivers I have to get. Like sound, gfx cards, etc, I know but I'm sure there are some hidden ones along there. Do I have to reinstall the motherboard, etc.
If anyone can help or give me some advice it would be greatly appreaciated.
Thanks
Thanks
