Ok, this upgrade is turning into a HUGE nightmare.
Below is a screenshot of my current setup. Obviously the system is bootable at this point, but I've had no luck doing what I want to: I want to move the contents of drive C: to drive K:, and then rename drive K: to drive C: (removing the old drive from the system) ... The OS is WinXP Pro SP1, btw ...
click to enlarge
So far I've tried Seagate DiscWizard, it manages to transfer all the data but then when I remove the original drive, I get an "OS can not be found" message when booting. I tried using FDISK /MBR (from a Win98 boot disk) but that didn't help. I also tried using Seagate DiscWizard's MBR repair utility, but that didn't help either.
Apparently I'm running into problems because I've exceeded the 1024 cylinder limit, or something like that. This strikes me as odd though, since my current WinXP install ALSO exceeds the 1024 limit, yet works just fine. ???
I've also tried using DriveImage 2002, but that program fails while loading, with error #91 (Disc Manager detected but not running) ... I went in using FDISK (using the "/CMBR 1" switch) but that didn't help - DriveImage still refuses to load.
So basically, I'm stuck. I've wasted about 12 hours transfering the data from C: to K: (I've tried it twice already, using Seagate's DiscWizard) and so far the only way I can get this damn PC to boot is to leave the old drive in. What gives???
Any suggestions would be appreciated!!!
click to enlarge
