scratchnasty
- May 8, 2005
Hi all:
I picked up an iRiver T10 mp3 player yesterday and after many failed attempts at getting Windows XP to recognize the device I decided I may need a BIOS update to get it working. I'm using an Abit AS8-3rd Eye MB which is based on the Intel 865PE chipset. I downloaded the flashmenu utility from Abit as well as the latest BIOS revision (version 18). I was using version 17 which came with the board.
All seemed well after executing the BIOS revision, no worries. Now when I boot I get a "disk read failure" error and I'm asked to ctrl+alt+del to restart. Here are some specs on the system for reference:
Intel P4 3.0 socket775
1GB Dual-channel DDR (512 x2)
WD Caviar 80GB HDD (x2 in RAID 0 array)
3.5" floppy
2 optical drives (if you need to know more about these please ask)
I've checked, rechecked, and checked 3, 4, and 5 times the BIOS and everything looks perfect, but you know how that can be. So my questions I suppose is can there be a problem flashing BIOS when you're using a RAID and the settings might be changed? Shouldn't it be as simple (I hesitate using that word) as changing the settings back if they're altered to match what you had before or could that hose the RAID? I don't mind wiping this comp and starting over but I would prefer keeping it in it's pre-hosed state and continuing with it.
Here's a link to the MB site for my model if you need some more thorough info. Thanks in advance to anyone that might be able to help.
Abit AS8-3rd Eye
By the way, should I be clearing the CMOS after flashing the BIOS?
3.5" floppy
Abit AS8-3rd Eye
