silentnswift
- Jul 18, 2005
I have a router that I set up with WEP and I block all MAC addresses except for my wireless adapter. I did ipconfig/all on the computer with the Wireless Adapter, and copied the MAC adress into the Access List so I can connect. I set up my router with the 128bit Passphrase, and try to connect, and normally it works. However, randomly after I restart the computer, I will fail to Authenticate. I made sure I typed the passphrase right, and when I switch from infrastructure to 802.11 Ad-Hoc (I have no idea what that is) I can connect. But when I go to infrastucture, which is the only way to use the internet, I can never authenticate. Can anyone help?
